System Administration Guide: Devices and File Systems
ProcedureHow to Display UFS Snapshot Information
You can display the current snapshots on the system by using the fssnap -i option. If you specify a file system, you see detailed information about that file system snapshot. If you don't specify a file system, you see information about all of the current UFS snapshots and their corresponding virtual devices.
Note –
Use the UFS file system-specific fssnap command to view the extended snapshot information as shown in the following examples.
  1. Become superuser or assume an equivalent role.
  2. List all current snapshots.
    For example:
    # /usr/lib/fs/ufs/fssnap -i
    Snapshot number               : 0
    Block Device                  : /dev/fssnap/0
    Raw Device                    : /dev/rfssnap/0
    Mount point                   : /export/home
    Device state                  : idle
    Backing store path            : /var/tmp/snapshot0
    Backing store size            : 0 KB
    Maximum backing store size    : Unlimited
    Snapshot create time          : Mon Jul 12 10:37:50 2010
    Copy-on-write granularity     : 32 KB
  3. Display detailed information about a specific snapshot.
    For example:
    # /usr/lib/fs/ufs/fssnap -i /export
    Snapshot number               : 1
    Block Device                  : /dev/fssnap/1
    Raw Device                    : /dev/rfssnap/1
    Device state                  : idle
    Backing store path            : /var/tmp/snapshot1
