System Administration Guide: Devices and File Systems
Packing a Cached File System (Task Map)
The following task map describes the procedures that are associated with packing a CacheFS file system. All of these procedures are optional.
Task
Description
For Instructions
Pack files in the cache.
Identify files and directories to be loaded in the cache and pack them. Packing ensures that current copies of these files are available in the cache.
How to Pack Files in the Cache
Create a packing list.
Create a packing list if you do not want to specify each individual file that you want packed in the cache.
How to Create a Packing List
Pack files in the cache with a packing list.
Specify the name of the packing list of the files to be packed in the cache.
How to Pack Files in the Cache With a Packing List
Unpack files or packing lists from the cache.
Remove a file from the cache that is no longer needed.
How to Unpack Files or Packing Lists From the CacheHow to Unpack Files or Packing Lists From the Cache
Display packed files information.
View information about the files that you've packed, including their packing status.
How to Display Packed Files Information
