System Administration Guide: Devices and File Systems
ProcedureHow to Restore a Bad Superblock (Solaris 8, 9, and 10 Releases)
  1. Become superuser or assume an equivalent role.
  2. Determine whether the bad superblock is in the root (/), /usr, or /var file system and select one of the following:
  3. Display the superblock values by using the newfs -N command.
    # newfs -N /dev/rdsk/device-name
    The command output displays the block numbers that were used for the superblock copies when the newfs command created the file system, unless the file system was created with special parameters. For information on creating a customized file system, see Customizing UFS File System Parameters.
  4. Provide an alternate superblock by using the fsck command.
    # fsck -F ufs -o b=block-number /dev/rdsk/device-name
    The fsck command uses the alternate superblock you specify to restore the primary superblock. You can always try 32 as an alternate block. Or, use any of the alternate blocks shown by the newfs -N command.
Example 21–3 Restoring a Bad Superblock (Solaris 8, 9, and 10 Releases)
The following example shows how to restore the superblock copy 5264.
# newfs -N /dev/rdsk/c0t3d0s7
/dev/rdsk/c0t3d0s7: 163944 sectors in 506 cylinders of 9 tracks, 36 sectors
 83.9MB in 32 cyl groups (16 c/g, 2.65MB/g, 1216 i/g)
super-block backups (for fsck -b #) at:
 32, 5264, 10496, 15728, 20960, 26192, 31424, 36656, 41888,
 47120, 52352, 57584, 62816, 68048, 73280, 78512, 82976, 88208,
 93440, 98672, 103904, 109136, 114368, 119600, 124832, 130064, 135296,
 140528, 145760, 150992, 156224, 161456,
# fsck -F ufs -o b=5264 /dev/rdsk/c0t3d0s7
Alternate superblock location: 5264.
** /dev/rdsk/c0t3d0s7
** Last Mounted on
** Phase 1 - Check Blocks and Sizes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
36 files, 867 used, 75712 free (16 frags, 9462 blocks, 0.0% fragmentation)
***** FILE SYSTEM WAS MODIFIED *****
