Skip Navigation Links
Exit Print View
Developer's Guide to Oracle Solaris Security     Oracle Solaris 10 8/11 Information Library
search filter icon
search icon
Document Information
Preface
1.  Oracle Solaris Security for Developers (Overview)
2.  Developing Privileged Applications
3.  Writing PAM Applications and Services
4.  Writing Applications That Use GSS-API
5.  GSS-API Client Example
6.  GSS-API Server Example
7.  Writing Applications That Use SASL
8.  Introduction to the Oracle Solaris Cryptographic Framework
9.  Writing User-Level Cryptographic Applications and Providers
10.  Using the Smart Card Framework
A.  Sample C-Based GSS-API Programs
B.  GSS-API Reference
GSS-API Functions
Functions From Previous Versions of GSS-API
Functions for Manipulating OIDs
Renamed Functions
GSS-API Status Codes
GSS-API Major Status Code Values
Displaying Status Codes
Status Code Macros
GSS-API Data Types and Values
Basic GSS-API Data Types
OM_uint32
gss_buffer_desc
gss_OID_desc
gss_OID_set_desc
gss_channel_bindings_struct
Name Types
Address Types for Channel Bindings
Implementation-Specific Features in GSS-API
Oracle Solaris-Specific Functions
Human-Readable Name Syntax
Format of Anonymous Names
Implementations of Selected Data Types
Deletion of Contexts and Stored Data
Protection of Channel-Binding Information
Context Exportation and Interprocess Tokens
Types of Credentials Supported
Credential Expiration
Context Expiration
Wrap Size Limits and QOP Values
Use of minor_status Parameter
Kerberos v5 Status Codes
Messages Returned in Kerberos v5 for Status Code 1
Messages Returned in Kerberos v5 for Status Code 2
Messages Returned in Kerberos v5 for Status Code 3
Messages Returned in Kerberos v5 for Status Code 4
Messages Returned in Kerberos v5 for Status Code 5
Messages Returned in Kerberos v5 for Status Code 6
Messages Returned in Kerberos v5 for Status Code 7
C.  Specifying an OID
D.  Source Code for SASL Example
E.  SASL Reference Tables
F.  Packaging and Signing Cryptographic Providers
Glossary
Index
Appendix B
GSS-API Reference
This appendix includes the following sections:
Additional GSS-API definitions can be found in the file gssapi.h.
