Skip Navigation Links
Exit Print View
Oracle Solaris Administration: Network Services     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
Part I Network Services Topics
1.  Network Service (Overview)
2.  Managing Web Cache Servers
3.  Time-Related Services
Part II Accessing Network File Systems Topics
4.  Managing Network File Systems (Overview)
5.  Network File System Administration (Tasks)
6.  Accessing Network File Systems (Reference)
Part III SLP Topics
7.  SLP (Overview)
8.  Planning and Enabling SLP (Tasks)
9.  Administering SLP (Tasks)
10.  Incorporating Legacy Services
11.  SLP (Reference)
Part IV Mail Services Topics
12.  Mail Services (Overview)
13.  Mail Services (Tasks)
14.  Mail Services (Reference)
Part V Serial Networking Topics
15.  Solaris PPP 4.0 (Overview)
16.  Planning for the PPP Link (Tasks)
17.  Setting Up a Dial-up PPP Link (Tasks)
18.  Setting Up a Leased-Line PPP Link (Tasks)
19.  Setting Up PPP Authentication (Tasks)
20.  Setting Up a PPPoE Tunnel (Tasks)
21.  Fixing Common PPP Problems (Tasks)
22.  Solaris PPP 4.0 (Reference)
Using PPP Options in Files and on the Command Line
Where to Define PPP Options
How PPP Options Are Processed
How PPP Configuration File Privileges Work
User Privileges
File Privileges
Effects of Option Privileges
/etc/ppp/options Configuration File
/etc/ppp/options.tmpl Template
Where to Find Examples of the /etc/ppp/options Files
/etc/ppp/options.ttyname Configuration File
Using /etc/ppp/options.ttyname on a Dial-in Server
Using /etc/ppp/options.ttyname on a Dial-out Machine
options.ttya.tmpl Template File
Where to Find Examples of the /etc/ppp/options.ttyname Files
Configuring User-Specific Options
Configuring $HOME/.ppprc on a Dial-in Server
Configuring $HOME/.ppprc on a Dial-out Machine
Specifying Information for Communicating With the Dial-in Server
/etc/ppp/peers/peer-name File
/etc/ppp/peers/myisp.tmpl Template File
Where to Find Examples of the /etc/ppp/peers/peer-name Files
Configuring Modem Speed for a Dial-up Link
Defining the Conversation on the Dial-up Link
Contents of the Chat Script
Chat Script Examples
Basic Modem Chat Script
/etc/ppp/myisp-chat.tmpl Chat Script Template
Modem Chat Script for Calling an ISP
Basic Chat Script Enhanced for a UNIX-Style Login
Chat Script for External ISDN TA
For More Chat Script Examples
Invoking the Chat Script
How to Invoke a Chat Script (Task)
Creating a Chat File That Is Executable
How to Create an Executable Chat Program
Authenticating Callers on a Link
Password Authentication Protocol (PAP)
/etc/ppp/pap-secrets File
Creating PAP Passwords
What Happens During PAP Authentication
Using the login Option With /etc/ppp/pap-secrets
Challenge-Handshake Authentication Protocol (CHAP)
/etc/ppp/chap-secrets File
What Happens During CHAP Authentication
Creating an IP Addressing Scheme for Callers
Assigning Dynamic IP Addresses to Callers
Assigning Static IP Addresses to Callers
Assigning IP Addresses by sppp Unit Number
Creating PPPoE Tunnels for DSL Support
Files for Configuring Interfaces for PPPoE
/etc/ppp/pppoe.if File
/usr/sbin/sppptun Command
Examples of sppptun Commands for Administering Interfaces
PPPoE Access Server Commands and Files
/usr/lib/inet/pppoed Daemon
/etc/ppp/pppoe File
/etc/ppp/pppoe.device File
pppoe.so Plugin
Using PPPoE and PPP Files to Configure an Access Server
PPPoE Client Commands and Files
/usr/lib/inet/pppoec Utility
pppoe.so Shared Object
/etc/ppp/peers/peer-name File for Defining an Access Server Peer
23.  Migrating From Asynchronous Solaris PPP to Solaris PPP 4.0 (Tasks)
24.  UUCP (Overview)
25.  Administering UUCP (Tasks)
26.  UUCP (Reference)
Part VI Working With Remote Systems Topics
27.  Working With Remote Systems (Overview)
28.  Administering the FTP Server (Tasks)
29.  Accessing Remote Systems (Tasks)
Part VII Monitoring Network Services Topics
30.  Monitoring Network Performance (Tasks)
Glossary
Index
Solaris PPP 4.0 contains a large set of options, which you use to define your PPP configuration. You use these options in the PPP configuration files, or on the command line, or by using a combination of files and command-line options. This section contains detailed information about the use of PPP options in configuration files and as arguments to PPP commands.
Solaris PPP 4.0 configuration is very flexible. You can define PPP options in the following places:
The next table lists the PPP configuration files and commands.
Table 22-1 Summary of PPP Configuration Files and Commands
File or Command
Description
For Information
/etc/ppp/options
A file that contains characteristics that apply by default to all PPP links on the system, for example, whether the machine requires peers to authenticate themselves. If this file is absent, nonroot users are prohibited from using PPP.
A file that describes the characteristics of all communications over the serial port ttyname.
/etc/ppp/peers
Directory that usually contains information about peers with which a dial-out machine connects. Files in this directory are used with the call option of the pppd command.
A file that contains characteristics of the remote peer peer-name. Typical characteristics include the remote peer's phone number and chat script for negotiating the link with the peer.
A file that contains the necessary security credentials for Password Authentication Protocol (PAP) authentication.
A file that contains the necessary security credentials for Challenge-Handshake Authentication Protocol (CHAP) authentication.
~/.ppprc
File in the home directory of a PPP user, most often used with dial-in servers. This file contains specific information about each user's configuration.
pppd options
Command and options for initiating a PPP link and describing its characteristics.
Refer to the pppd(1M) man page for details on the PPP files. pppd (1M) also includes comprehensive descriptions of all options that are available to the pppd command. Sample templates for all the PPP configuration files are available in /etc/ppp.
  1. The pppd daemon parses the following:
    All Solaris PPP 4.0operations are handled by the pppd daemon, which starts when a user runs the pppd command. When a user calls a remote peer, the following occurs:
    • /etc/ppp/options
    • $HOME/.ppprc
    • Any files that are opened by the file or call option in /etc/ppp/options and $HOME/.ppprc
  2. pppd scans the command line to determine the device in use. The daemon does not yet interpret any options that are encountered.
  3. pppd tries to discover the serial device to use by using these criteria:
    • If a serial device is specified on the command line, or a previously processed configuration file, pppd uses the name of that device.
    • If no serial device is named, then pppd searches for the notty, pty, or socket option on the command line. If one of these options is specified, pppd assumes that no device name exists.
    • Otherwise, if pppd discovers that standard input is attached to a tty, then the name of the tty is used.
    • If pppd still cannot find a serial device, pppd terminates the connection and issues an error.
  4. pppd then checks for the existence of the /etc/ppp/options.ttyname file. If the file is found, pppd parses the file.
  5. pppd processes any options on the command line.
  6. pppd negotiates the Link Control Protocol (LCP) to set up the link.
  7. (Optional) If authentication is required, pppd reads /etc/ppp/pap-secrets or /etc/ppp/chap-secrets to authenticate the opposite peer.
The file /etc/ppp/peers/peer-name is read when the pppd daemon encounters the option call peer-name on the command line or in the other configuration files.
Solaris PPP 4.0 configuration includes the concept of privileges. Privileges determine the precedence of configuration options, particularly when the same option is invoked in more than one place. An option that is invoked from a privileged source takes precedence over the same option that is invoked from a nonprivileged source.
User Privileges
The only privileged user is superuser (root), with the UID of zero. All other users are not privileged.
File Privileges
The following configuration files are privileged regardless of their ownership:
The file $HOME/.ppprc is owned by the user. Options that are read from $HOME/.ppprc and from the command line are privileged only if the user who is invoking pppd is root.
Arguments that follow the file option are privileged.
Some options require the invoking user or source to be privileged in order to work. Options that are invoked on the command line are assigned the privileges of the user who is running the pppd command. These options are not privileged unless the user who is invoking pppd is root.
Option
Status
Explanation
domain
Privileged
Requires privileges for use.
linkname
Privileged
noauth
Privileged
nopam
Privileged
pam
Privileged
plugin
Privileged
privgroup
Privileged
allow-ip addresses
Privileged
name hostname
Privileged
plink
Privileged
noplink
Privileged
plumbed
Privileged
proxyarp
Becomes privileged if noproxyarp has been specified
Cannot be overridden by an unprivileged use.
defaultroute
Privileged if nodefaultroute is set in a privileged file or by a privileged user
Cannot be overridden by an unprivileged user.
disconnect
Privileged if set in a privileged file or by a privileged user
bsdcomp
The nonprivileged user cannot specify a code size that is larger than the privileged user has specified.
deflate
connect
Cannot be overridden by an nonprivileged user.
init
pty
welcome
ttyname
Not privileged if set in a nonprivileged file
Opened with root permissions regardless of who invokes pppd.
Opened with the privileges of the user who invokes pppd.
You use the /etc/ppp/options file to define global options for all PPP communications on the local machine. /etc/ppp/options is a privileged file. /etc/ppp/options should be owned by root, although pppd does not enforce this rule. Options that you define in /etc/ppp/options have precedence over definitions of the same options in all other files and the command line.
Typical options that you might use in /etc/ppp/options include the following:
Note - The Solaris PPP 4.0 software does not include a default /etc/ppp/options file. pppd does not require the /etc/ppp/options file to work. If a machine does not have an /etc/ppp/options file, only root can run pppd on that machine.
You must create /etc/ppp/options by using a text editor, as shown in How to Define Communications Over the Serial Line. If a machine does not require global options, you can create an empty /etc/ppp/options file. Then, both root and regular users can run pppd on the local machine.
The /etc/ppp/options.tmpl contains helpful comments about the /etc/ppp/options file plus three common options for the global /etc/ppp/options file.
lock
nodefaultroute
noproxyarp
Option
Definition
lock
Enables UUCP-style file locking
nodefaultroute
Specifies that no default route is defined
noproxyarp
Disallows proxyarp
To use /etc/ppp/options.tmpl as the global options file, rename /etc/ppp/options.tmpl to /etc/ppp/options. Then, modify the file contents as needed by your site.
To find examples of the /etc/ppp/options file, refer to the following:
You can configure the characteristics of communications on the serial line in the /etc/ppp/options.ttyname file. /etc/ppp/options.ttyname is a privileged file that is read by pppd after parsing any existing /etc/ppp/options and existing $HOME/.ppprc files. Otherwise, pppd reads /etc/ppp/options.ttyname after parsing /etc/ppp/options.
ttyname is used for both dial-up and leased-line links. ttyname represents a particular serial port on a machine, such as cua/a or cua/b, where a modem or ISDN TA might be attached.
When naming the /etc/ppp/options.ttyname file, replace the slash (/) in the device name with a dot (.). For example, the options file for device cua/b should be named /etc/ppp/options.cua.b.
Note - Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. Your server might have only one serial line for PPP. Furthermore, the server requires few options. In this instance, you can specify any required options in another configuration file or on the command line.
For a dial-up link, you might choose to create individual /etc/ppp/options.ttyname files for every serial port on a dial-in server with a modem attached. Typical options include the following:
For a dial-out system, you can create an /etc/ppp/options.ttyname file for the serial port that is connected to the modem, or choose not to use /etc/ppp/options.ttyname.
Note - Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. A dial-out machine might have only one serial line for PPP. Furthermore, the dial-out machine might require few options. You can specify any required options in another configuration file or on the command line.
The /etc/ppp/options.ttya.tmpl file contains helpful comments about the /etc/ppp/options.tty-name file. The template contains three common options for the /etc/ppp/options.tty-name file.
38400
asyncmap 0xa0000
:192.168.1.1
Option
Definition
38400
Use this baud rate for port ttya.
asyncmap 0xa0000
Assign the asyncmap value of 0xa0000 so that the local machine can communicate with broken peers.
:192.168.1.1
Assign the IP address 192.168.1.1 to all peers that are calling in over the link.
To use /etc/ppp/options.ttya.tmpl at your site, rename /etc/ppp/options.tmpl to /etc/ppp/options.ttya-name. Replace ttya-name with the name of the serial port with the modem. Then modify the file contents as needed by your site.
To find examples of the /etc/ppp/options.ttyname files, refer to the following:
