Skip Navigation Links
Exit Print View
man pages section 9: DDI and DKI Driver Entry Points     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
Introduction
Driver Entry Points
aread(9E)
attach(9E)
audio_engine_channels(9E)
audio_engine_chinfo(9E)
audio_engine_close(9E)
audio_engine_count(9E)
audio_engine_format(9E)
audio_engine_open(9E)
audio_engine_playahead(9E)
audio_engine_qlen(9E)
audio_engine_rate(9E)
audio_engine_start(9E)
audio_engine_stop(9E)
audio_engine_sync(9E)
awrite(9E)
chpoll(9E)
close(9E)
csx_event_handler(9E)
detach(9E)
devmap(9E)
devmap_access(9E)
devmap_contextmgt(9E)
devmap_dup(9E)
devmap_map(9E)
devmap_unmap(9E)
dump(9E)
_fini(9E)
getinfo(9E)
gld(9E)
gldm_get_stats(9E)
gldm_intr(9E)
gldm_ioctl(9E)
gldm_reset(9E)
gldm_send(9E)
gldm_set_mac_addr(9E)
gldm_set_multicast(9E)
gldm_set_promiscuous(9E)
gldm_start(9E)
gldm_stop(9E)
identify(9E)
_info(9E)
_init(9E)
ioctl(9E)
ks_snapshot(9E)
ks_update(9E)
mac(9E)
mac_capab_rings(9E)
mac_group_info(9E)
mac_ring_info(9E)
mc_getcapab(9E)
mc_getprop(9E)
mc_getstat(9E)
mc_ioctl(9E)
mc_multicst(9E)
mc_propinfo(9E)
mc_setpromisc(9E)
mc_setprop(9E)
mc_start(9E)
mc_stop(9E)
mc_tx(9E)
mc_unicst(9E)
mgi_addmac(9E)
mgi_add_vlanfilter(9E)
mgi_getsriov_info(9E)
mgi_remmac(9E)
mgi_rem_vlanfliter(9E)
mgi_setmtu(9E)
mgi_start(9E)
mgi_stop(9E)
mmap(9E)
mr_gaddring(9E)
mr_gget(9E)
mr_gremring(9E)
mri_intr_disable(9E)
mri_intr_enable(9E)
mr_rget(9E)
open(9E)
power(9E)
prefix_ring_poll(9E)
prefix_ring_start(9E)
prefix_ring_stat(9E)
prefix_ring_stop(9E)
prefix_ring_tx(9E)
print(9E)
probe(9E)
prop_op(9E)
put(9E)
quiesce(9E)
read(9E)
segmap(9E)
srv(9E)
strategy(9E)
tran_abort(9E)
tran_bus_reset(9E)
tran_destroy_pkt(9E)
tran_dmafree(9E)
tran_getcap(9E)
tran_init_pkt(9E)
tran_pkt_constructor(9E)
tran_pkt_destructor(9E)
tran_quiesce(9E)
tran_reset(9E)
tran_reset_notify(9E)
tran_setcap(9E)
tran_setup_pkt(9E)
tran_start(9E)
tran_sync_pkt(9E)
tran_teardown_pkt(9E)
tran_tgt_free(9E)
tran_tgt_init(9E)
tran_tgt_probe(9E)
tran_unquiesce(9E)
write(9E)
audio_engine_count
- return the sample count for an audio engine
Synopsis
#include <sys/audio/audio_driver.h>
uint64_t prefix_count(void *state);
Parameters
state
pointer to driver supplied soft state
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_engine_count() function returns the frame count of the engine, which is the number of frames transferred by the engine since it was last opened with audio_engine_open(9E).
For recording, this frame count will be the total number of frames that the engine has written into the buffer. For playback, it will be the number of frames that the engine has read from the buffer. This value is monotonically increasing and does not wrap.
The audio_engine_open() function, however, will reset the frame count to 0.
The frame count for the engine is related to the offset of the data in the buffer. Both normally increase as the engine makes progress, but the engine index wraps when it reaches the end of the buffer or when the device is stopped and restarted with audio_engine_stop(9E) and audio_engine_start(9E).
Return Values
The audio_engine_count() function returns the number of frames transferred by the engine since audio_engine_open() was called.
Context
This function may be called from user or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
attributes(5), audio(7D), audio_engine_open(9E), audio_engine_start(9E), audio_engine_stop(9E), audio_engine_ops(9S)
