You must import the datastores prior to importing the customized ETL tasks.
The following steps are implemented in the DEV repository only. To migrate changes to TEST and PROD repositories, see My Oracle Support document (ID 1587872.1) titled BI Applications 11.1.1.7.1 – Migrating Configurations and Customizations from Development to a Test OR Production Environment.The upgrade datastores will now be merged with the pre-upgrade customizations.
