Upgrading the Repository
Follow these instructions to upgrade the repository using the BI Update Metatdata Tool.
To upgrade the repository using the BI Update Metatdata Tool:
  1. Take a backup of the repository.
  2. Create a writable directory where logs will be stored.
    For example, C:\RPD_Upgrade or WORKDIR_HOME/ RPD_Upgrade
  3. Run the following command to upgrade the repository:
    <BI_Oracle_Home>/jdk/jre/bin/java -cp
    <BI_Oracle_Home>/biapps/patch/biappspatch.jar
    oracle.as.biapps.patch.update.UpdateBIAppsMetadata bi.oracle.home=<BI Oracle Home> bi.admin.url=<BI EM Admin URL> bi.admin.username=<bi EM Admin User>
    bi.admin.password=<BI EM Admin User Password> only.apply=rpd log.file=<Work dir>/rpd.log log.level=FINEST work.dir=<writable work dir path>
    saas.env=false
    Example:
    /Middleware_Home/Oracle_BI1/jdk/jre/bin/java -cp
    /Middleware_Home/Oracle_BI1/biapps/patch/biappspatch.jar
    bi.oracle.home=/Middleware_Home>/Oracle_BI1 bi.admin.url=http://host:7001
    bi.admin.username=weblogic bi.admin.password=password only.apply=rpd
    log.file=/WORKDIR_HOME/RPD_Upgrade/rpd.log log.level=FINEST
    work.dir=/WORKDIR_HOME/RPD_Upgrade saas.env=false
    For example: After the process starts, you are prompted with the password.
    Optional Parameters:log.level - the default is INFO. The valid values are FINEST, FINE, INFO, WARNING, SEVERE.
