Financials
New ETL content in Financials after the upgrade from 11.1.1.10.1 to 11.1.1.10.2 is listed in this topic.
Payables (AP)
Following are the upgrade changes:
  1. Tables truncated or records deleted:
    • W_AP_XACT_FS (truncated)
    • W_AP_XACT_F (deleted and inserted)
  2. New columns included in base fact:
    NA
  3. Tables with records added:
    NA
  4. Metrics calculated differently:
    NA
  5. Issues and bug fixes covered:
    Enhancement/Bug Impacted warehouse object Impacted adapters
    To update the Validation Status (VALD_STATUS_WID)
    BUG 21923351 INCLUDE FTS_FUSION_FSCMTOPMODELAM_FINAPINVTRANSACTIONSAM_INVOICEHEADERPVO IN LP
    W_AP_XACT_F
    Fusion
  6. New attributes:
    NA
  7. Data model changes:
    NA
Receivables (AR)
    NA
  2. New columns added in base fact:
    NA
    W_XACT_TYPE_D (where INTEGRATION_ID like ['ACCT_DOC~RECEIVABLE~CASH APPLICATION~EDISC','ACCT_DOC~RECEIVABLE~CASH APPLICATION~UNEDISC'])
    W_AR_XACT_F
    Will extract the new discount distributions EDISC,UNEDISC where INTEGRATION_ID like 'R~%'
    AR Discount related metrics
  5. Issues and bug fixes:
    BUG 20651741 REL11-Discounts are seen to be multiplying based on AR Distributions
    W_XACT_TYPE_D
    W_AR_XACT_F
    Fusion
    R12xx
  6. New Attributes:L
    NA
  7. Data Model Change:
    NA
General Ledger (GL)
    • W_GL_LINKAGE_INFORMATION_GS
    NA
    Inserted Fusion Apps specific application id '10036' to W_GL_LINKAGE_INFORMATION_G
    NA
    Bug 22199884 - OTBI-E V3: SOURCE_DISTRIBUTION_ID not correctly populated for Project Rev rows
    Bug 20525667 - Error in logic for DISTRIBUTION_SOURCE and SOURCE_DISTRIBUTION_ID in linkage
    Fusion
  6. New attributes:
    NA
    NA
COGS/Profitability/Revenue
    NA
    NA
    NA
    NA
    Bug 21490311 - FIN R10: INIT: PSR: SDE_ORA_GLREVENUEFACT session failed with ORA-12899
    W_GL_REVN_FS
    W_GL_REVN_F
    W_GL_REVN_RECON_FS
    W_GL_REVN_REV_RECON_FS
    ALL
  6. New attributes:
    NA
    Change the data type of column SALES_ORDER_DOC from varchar2(30) to varchar2(50) in the following tables:
    • W_GL_REVN_FS
    • W_GL_REVN_F
    • W_GL_REVN_RECON_FS
    • W_GL_REVN_REV_RECON_FS
Fixed Asset (FA)
The following are the upgrade changes:
    NA
    NA
    NA
    NA
    Bug 22888791 - REL11.1:EBS122:INCR:SIL_FIXEDASSETLEASEPAYMENTFACT-Invalid number
    W_FA_LEASE_PAYMENT_F
    W_FA_LEASE_PAYMENT_FS
    ALL
  6. New attributes:
    NA
    1. Table: W_FA_LEASE_PAYMENT_F : Change data type of following columns from VARCHAR2(10 CHAR) to NUMBER(28,10)
      • LOC_EXCHANGE_RATE
      • GLOBAL1_EXCHANGE_RATE
      • GLOBAL2_EXCHANGE_RATE
      • GLOBAL3_EXCHANGE_RATE
    2. Table: W_FA_LEASE_PAYMENT_FS : Change data type of the columns LOC_EXCHANGE_RATE from VARCHAR2(10 CHAR) to NUMBER(28,10)
