4 Using SQL Statements in OCI
This chapter discusses the concepts and steps involved in processing SQL statements with the Oracle Call Interface.
This chapter contains these topics:
Overview of SQL Statement Processing
Chapter 2, "OCI Programming Basics" discussed the basic steps involved in any OCI application. This chapter presents a more detailed look at the specific tasks involved in processing SQL statements in an OCI program.
One of the most common tasks of an OCI program is to accept and process SQL statements. This section outlines the specific steps involved in this processing.
Once you have allocated the necessary handles and connected to a server, follow the steps illustrated in Figure 4-1, "Steps In Processing SQL Statements":
Figure 4-1 Steps In Processing SQL Statements
Description of Figure 4-1 follows
Description of "Figure 4-1 Steps In Processing SQL Statements"
  1. Prepare statement. Define an application request using OCIStmtPrepare() or OCIStmtPrepare2().
  2. Bind placeholders, if necessary.. For DML statements and queries with input variables, perform one or more bind calls using
    • OCIBindByPos()
    • OCIBindByName()
    • OCIBindObject()
    • OCIBindDynamic()
    • OCIBindArrayOfStruct()
    to bind the address of each input variable (or PL/SQL output variable) or array to each placeholder in the statement.
  3. A statement can also be prepared for execution with OCIStmtPrepare2(), an enhanced version of OCIStmtPrepare() introduced to support statement caching.
  4. Execute. Call OCIStmtExecute() to execute the statement. For DDL statements, no further steps are necessary.
  5. Describe, if necessary. Describe the select-list items, if necessary, using OCIParamGet() and OCIAttrGet(). This is an optional step; it is not required if the number of select-list items and the attributes of each item (such as its length and datatype) are known at compile time.
  6. Define, if necessary. For queries, perform one or more define calls to OCIDefineByPos(), OCIDefineObject(), OCIDefineDynamic(), or OCIDefineArrayOfStruct() to define an output variable for each select-list item in the SQL statement. Note that you do not use a define call to define the output variables in an anonymous PL/SQL block. You have done this when you have bound the data.
  7. Fetch, if necessary. For queries, call OCIStmtFetch() to fetch the results of the query.
Following these steps, the application can free allocated handles and then detach from the server, or it may process additional statements.
7.x Upgrade Note:
OCI programs no longer require an explicit parse step. If a statement must be parsed, that step takes place upon execution. This means that 8.0 or later applications must issue an execute command for both DML and DDL statements.
For each of the steps in the diagram, the corresponding OCI function calls are listed. In some cases multiple calls may be required.
Each step is described in detail in the following sections.
Some variation in the order of steps is possible. For example, it is possible to do the define step before the execute if the datatypes and lengths of returned values are known at compile time.
Additional steps beyond those listed earlier may be required if your application needs to do any of the following:
  • initiate and manage multiple transactions
  • manage multiple threads of execution
  • perform piecewise inserts, updates, or fetches
Preparing Statements
SQL and PL/SQL statements are prepared for execution by using the statement prepare call and any necessary bind calls. In this phase, the application specifies a SQL or PL/SQL statement and binds associated placeholders in the statement to data for execution. The client-side library allocates storage to maintain the statement prepared for execution.
An application requests a SQL or PL/SQL statement to be prepared for execution using the OCIStmtPrepare() call and passes to it a previously allocated statement handle. This is a completely local call, requiring no round trip to the server. No association is made between the statement and a particular server at this point.
Following the request call, an application can call OCIAttrGet() on the statement handle, passing OCI_ATTR_STMT_TYPE to the attrtype parameter, to determine what type of SQL statement was prepared. The possible attribute values and corresponding statement types are listed in Table 4-1, "OCI_ATTR_STMT_TYPE Values and Statement Types".
Table 4-1 OCI_ATTR_STMT_TYPE Values and Statement Types
Attribute Value Statement Type
SELECT statement
UPDATE statement
DELETE statement
INSERT statement
CREATE statement
DROP statement
ALTER statement
Using Prepared Statements on Multiple Servers
A prepared application request can be executed on multiple servers at run time by reassociating the statement handle with the respective service context handles for the servers. All information about the current service context and statement handle association is lost when a new association is made.
For example, consider an application such as a network manager, which manages multiple servers. In many cases, it is likely that the same SELECT statement will need to be executed against multiple servers to retrieve information for display. The OCI allows the network manager application to prepare a SELECT statement once and execute it against multiple servers. It must fetch all of the required rows from each server prior to reassociating the prepared statement with the next server.
If a prepared statement must be re-executed frequently on the same server, it is more efficient to prepare a new statement for another service context.
Binding Placeholders in OCI
Most DML statements, and some queries (such as those with a WHERE clause), require a program to pass data to Oracle as part of a SQL or PL/SQL statement. This data can be constant or literal, known when your program is compiled. For example, the following SQL statement, which adds an employee to a database contains several literals, such as 'BESTRY' and 2365:
    (2365, 'BESTRY', 'PROGRAMMER', 2000, 20)
Coding a statement like this into an application would severely limit its usefulness. You would need to change the statement and recompile the program each time you add a new employee to the database. To make the program more flexible, you can write the program so that a user can supply input data at run time.
When you prepare a SQL statement or PL/SQL block that contains input data to be supplied at run time, placeholders in the SQL statement or PL/SQL block mark where data must be supplied. For example, the following SQL statement contains five placeholders, indicated by the leading colons (:ename), that show where input data must be supplied by the program.
    (:empno, :ename, :job, :sal, :deptno)
You can use placeholders for input variables in any DELETE, INSERT, SELECT, or UPDATE statement, or a PL/SQL block, in any position in the statement where you can use an expression or a literal value. In PL/SQL, placeholders can also be used for output variables.
Placeholders cannot be used to represent other Oracle objects such as tables. For example, the following is not a valid use of the emp placeholder:
    (12345, 'OERTEL', 'WRITER', 50000, 30)
For each placeholder in a SQL statement or PL/SQL block, you must call an OCI routine that binds the address of a variable in your program to that placeholder. When the statement executes, Oracle gets the data that your program placed in the input, or bind, variables and passes it to the server with the SQL statement.
Binding is used for both input and output variables in non-query operations. In the following example,
empno_out, ename_out, job_out, sal_out, and deptno_out
should be bound. These are outbinds (as opposed to regular inbinds).
         (empno, ename, job, sal, deptno)
         (:empno_out, :ename_out, :job_out, :sal_out, :deptno_out)
See Also:
For detailed information about implementing bind operations, refer to Chapter 5, "Binding and Defining in OCI"
Executing Statements
An OCI application executes prepared statements individually using OCIStmtExecute().
When an OCI application executes a query, it receives data from Oracle that matches the query specifications. Within the database, the data is stored in Oracle-defined formats. When the results are returned, the OCI application can request that data be converted to a particular host language format, and stored in a particular output variable or buffer.
For each item in the select-list of a query, the OCI application must define an output variable to receive the results of the query. The define step indicates the address of the buffer and the type of the data to be retrieved.
If output variables are defined for a SELECT statement before a call to OCIStmtExecute(), the number of rows specified by the iters parameter are fetched directly into the defined output buffers and additional rows equivalent to the prefetch count are prefetched. If there are no additional rows, then the fetch is complete without calling OCIStmtFetch().
For non-queries, the number of times the statement is executed during array operations is equal to iters - rowoff, where rowoff is the offset in the bound array, and is also a parameter of the OCIStmtExecute() call.
For example, if an array of 10 items is bound to a placeholder for an INSERT statement, and iters is set to 10, all 10 items will be inserted in a single execute call when rowoff is zero. If rowoff is set to 2, only 8 items will be inserted.
See Also:
"Defining Output Variables in OCI" for more information about defining output variables
Execution Snapshots
The OCIStmtExecute() call provides the ability to ensure that multiple service contexts operate on the same consistent snapshot of the database's committed data. This is achieved by taking the contents of the snap_out parameter of one OCIStmtExecute() call and passing that value as the snap_in parameter of the next OCIStmtExecute() call.
Uncommitted data in one service context is not visible to another context, even when using the same snapshot.
The datatype of both the snap_out and snap_in parameter is OCISnapshot, an OCI snapshot descriptor that is allocated with the OCIDescAlloc() function.
It is not necessary to specify a snapshot when calling OCIStmtExecute(). The following sample code shows a basic execution in which the snapshot parameters are passed as NULL.
checkerr(errhp, OCIStmtExecute(svchp, stmthp, errhp, (ub4) 1, (ub4) 0,
          (OCISnapshot *)NULL, (OCISnapshot *) NULL, OCI_DEFAULT));
The checkerr() function, which is user-developed, evaluates the return code from an OCI application.
Execution Modes of OCIStmtExecute()
You can specify several modes for the OCIStmtExecute()call.
See Also:
"OCIStmtExecute()" for the values of the parameter mode
Batch Error Mode
OCI provides the ability to perform array DML operations. For example, an application can process an array of INSERT, UPDATE, or DELETE statements with a single statement execution. If one of the operations fails due to an error from the server, such as a unique constraint violation, the array operation aborts and OCI returns an error. Any rows remaining in the array are ignored. The application must then re-execute the remainder of the array, and go through the whole process again if it encounters more errors, which makes additional round trips.
To facilitate processing of array DML operations, OCI provides the batch error mode (also called the enhanced DML array feature). This mode, which is specified in the OCIStmtExecute() call, simplifies DML array processing in the event of one or more errors. In this mode, OCI attempts to INSERT, UPDATE, or DELETE all rows, and collects information about any errors that occurred. The application can then retrieve error information and re-execute any DML operations which failed during the first call.In this way, all DML operations in the array are attempted in the first call, and any failed operations can be reissued in a second call.
This feature is only available to applications linked with the 8.1 or later OCI libraries running against a release 8.1 or later server. Applications must also be re-coded to account for the new program logic described in this section.
This mode is used as follows:
  1. The user specifies OCI_BATCH_ERRORS as the mode parameter of the OCIStmtExecute() call.
  2. After performing an array DML operation with OCIStmtExecute(), the application can retrieve the number of errors encountered during the operation by calling OCIAttrGet() on the statement handle to retrieve the OCI_ATTR_NUM_DML_ERRORS attribute. For example:
    ub4   num_errs;
    OCIAttrGet(stmtp, OCI_HTYPE_STMT, &num_errs, 0, OCI_ATTR_NUM_DML_ERRORS,
  3. The application extracts each error using OCIParamGet(), along with its row information, from the error handle that was passed to the OCIStmtExecute() call. In order to retrieve the information, the application must allocate an additional new error handle for the OCIParamGet() call, populating the new error handle with batched error information. The application obtains the syntax of each error with OCIErrorGet(), and the row offset into the DML array at which the error occurred, by calling OCIAttrGet() on the new error handle.
    For example, once the num_errs amount has been retrieved, the application can issue the following calls:
    OCIError errhndl, errhp2;
    for (i=0; i<num_errs; i++)
       OCIParamGet(errhp, OCI_HTYPE_ERROR, errhp2, (dvoid **)&errhndl, i);
       OCIAttrGet(errhndl, OCI_HTYPE_ERROR, &row_offset, 0,
           OCI_ATTR_DML_ROW_OFFSET, errhp2);
       OCIErrorGet(..., errhndl, ...);
    Following this, the application can correct the bind information for the appropriate entry in the array using the diagnostic information retrieved from the batched error. Once the appropriate bind buffers are corrected or updated, the application can re-execute the associated DML statements.
    Since it cannot be determined at compile time which rows in the first execution will cause errors, the binds for the subsequent DML should be done dynamically by passing in the appropriate buffers at runtime. The bind buffers used in the array binds done on the first DML operation can be reused.
Example of Batch Error Mode
The following code shows an example of how this execution mode might be used. In this example assume that we have an application which inserts five rows (with two columns, of types NUMBER and CHAR) into a table. Furthermore, let us assume only two rows (say, 1 and 3) are successfully inserted in the initial DML operation. The user then proceeds to correct the data (wrong data was being inserted the first time) and to issue an update with the corrected data. The user uses statement handles stmtp1 and stmtp2 to issue the INSERT and UPDATE respectively.
OCIBind *bindp1[2], *bindp2[2];
ub4 num_errs, row_off[MAXROWS], number[MAXROWS] = {1,2,3,4,5};
char grade[MAXROWS] = {'A','B','C','D','E'};
OCIError *errhp2;
OCIError *errhndl[MAXROWS];
/* Array bind all the positions */
OCIBindByPos (stmtp1,&bindp1[0],errhp,1,(dvoid *)&number[0],
     sizeof(number[0]),SQLT_INT,(dvoid *)0, (ub2 *)0,(ub2 *)0,
            0,(ub4 *)0,OCI_DEFAULT);
OCIBindByPos (stmtp1,&bindp1[1],errhp,2,(dvoid *)&grade[0],
     sizeof(grade[0]),SQLT_CHR,(dvoid *)0, (ub2 *)0,(ub2 *)0,0,
/* execute the array INSERT */
OCIStmtExecute (svchp,stmtp1,errhp,5,0,0,0,OCI_BATCH_ERRORS);
/* get the number of errors, a different error handler errhp2 is used so that
 * the state of errhp is not changed */
OCIAttrGet (stmtp1, OCI_HTYPE_STMT, &num_errs, 0,
            OCI_ATTR_NUM_DML_ERRORS, errhp2);
if (num_errs) {
   /* The user can do one of two things: 1) Allocate as many  */
   /* error handles as number of errors and free all handles  */
   /* at a later time; or 2) Allocate one err handle and reuse */
   /* the same handle for all the errors */
   for (i = 0; i < num_errs; i++) {
      OCIHandleAlloc( (dvoid *)envhp, (dvoid **)&errhndl[i],
      (ub4) OCI_HTYPE_ERROR, 0, (dvoid *) 0);
      OCIParamGet(errhp, OCI_HTYPE_ERROR, errhp2, &errhndl[i], i);
      OCIAttrGet (errhndl[i], OCI_HTYPE_ERROR, &row_off[i], 0,
      /* get server diagnostics */
      OCIErrorGet (..., errhndl[i], ...);
/* make corrections to bind data */
OCIBindByPos (stmtp2,&bindp2[0],errhp,1,(dvoid *)0,sizeof(grade[0]),SQLT_INT,
     (dvoid *)0, (ub2 *)0,(ub2 *)0,0,(ub4 *)0,OCI_DATA_AT_EXEC);
OCIBindByPos (stmtp2,&bindp2[1],errhp,2,(dvoid *)0,sizeof(number[0]),SQLT_DAT,
/* register the callback for each bind handle, row_off and position
 * information can be passed to call back function by means of context
 * pointers.
OCIBindDynamic (bindp2[0],errhp,ctxp1,my_callback,0,0);
OCIBindDynamic (bindp2[1],errhp,ctxp2,my_callback,0,0);
/* execute the UPDATE statement */
OCIStmtExecute (svchp,stmtp2,errhp,num_errs,0,0,0,OCI_BATCH_ERRORS);
In this example, OCIBindDynamic() is used with a callback because the user does not know at compile time what rows will return with errors. With a callback, you can simply pass the erroneous row numbers, stored in row_off, through the callback context and send only those rows that need to be updated or corrected. The same bind buffers can be shared between the INSERT and the UPDATE executes.
Describing Select-list Items
If your OCI application is processing a query, you may need to obtain more information about the items in the select-list. This is particularly true for dynamic queries whose contents are not known until run time. In this case, the program may need to obtain information about the datatypes and column lengths of the select-list items. This information is necessary to define output variables that will receive query results.
For example, consider a query where the program has no prior information about the columns in the employees table:
SELECT * FROM employees
There are two types of describes available: implicit and explicit.
An implicit describe is one that does not require any special calls to retrieve describe information from the server, although special calls are necessary to access the information. An implicit describe allows an application to obtain select-list information as an attribute of the statement handle after a statement has been executed without making a specific describe call. It is called implicit, because no describe call is required. The describe information comes free with the execute.
An explicit describe is one which requires the application to call a particular function to bring the describe information from the server. An application may describe a select-list (query) either implicitly or explicitly. Other schema elements must be described explicitly.
You can describe a query explicitly prior to execution. To do this, specify OCI_DESCRIBE_ONLY as the mode of OCIStmtExecute(), which does not execute the statement, but returns the select-list description. For performance reasons it is recommended that applications take advantage of the implicit describe that comes free with a standard statement execution.
An explicit describe with the OCIDescribeAny() call obtains information about schema objects rather than select-lists.
In all cases, the specific information about columns and datatypes is retrieved by reading handle attributes.
See Also:
For information about using OCIDescribeAny() to obtain metadata pertaining to schema objects, refer to Chapter 6, "Describing Schema Metadata"
Implicit Describe
After a SQL statement is executed, information about the select-list is available as an attribute of the statement handle. No explicit describe call is needed.
To retrieve information about multiple select-list items, an application can call OCIParamGet() with the pos parameter set to 1 the first time, and then iterate the value of pos and repeat the OCIParamGet() call until OCI_ERROR with ORA-24334 is returned. An application could also specify any position n to get a column at random.
Once a parameter descriptor has been allocated for a position in the select-list, the application can retrieve specific information by calling OCIAttrGet() on the parameter descriptor. Information available from the parameter descriptor includes the datatype and maximum size of the parameter.
The following sample code shows a loop that retrieves the column names and datatypes corresponding to a query following query execution. The query was associated with the statement handle by a prior call to OCIStmtPrepare().
OCIParam     *mypard = (OCIParam *) 0;
ub2          dtype;
text         *col_name;
ub4          counter, col_name_len, char_semantics;
ub2          col_width;
sb4          parm_status;
text *sqlstmt = (text *)"SELECT * FROM employees WHERE employee_id = 100";
checkerr(errhp, OCIStmtPrepare(stmthp, errhp, (OraText *)sqlstmt,
                    (ub4)strlen((char *)sqlstmt),
                    (ub4) OCI_NTV_SYNTAX, (ub4) OCI_DEFAULT));
checkerr(errhp, OCIStmtExecute(svchp, stmthp, errhp, 0, 0, (OCISnapshot *)0, (OCISnapshot *)0, OCI_DEFAULT));
/* Request a parameter descriptor for position 1 in the select-list */
counter = 1;
parm_status = OCIParamGet((dvoid *)stmthp, OCI_HTYPE_STMT, errhp,
               (dvoid **)&mypard, (ub4) counter);
/* Loop only if a descriptor was successfully retrieved for
   current position, starting at 1 */
while (parm_status == OCI_SUCCESS) {
   /* Retrieve the datatype attribute */
   checkerr(errhp, OCIAttrGet((dvoid*) mypard, (ub4) OCI_DTYPE_PARAM,
           (dvoid*) &dtype,(ub4 *) 0, (ub4) OCI_ATTR_DATA_TYPE,
           (OCIError *) errhp  ));
   /* Retrieve the column name attribute */
   col_name_len = 0;
           (dvoid**) &col_name, (ub4 *) &col_name_len, (ub4) OCI_ATTR_NAME,
   /* Retrieve the length semantics for the column */
   char_semantics = 0;
           (dvoid*) &char_semantics,(ub4 *) 0, (ub4) OCI_ATTR_CHAR_USED,
   col_width = 0;
   if (char_semantics)
       /* Retrieve the column width in characters */
               (dvoid*) &col_width, (ub4 *) 0, (ub4) OCI_ATTR_CHAR_SIZE,
       /* Retrieve the column width in bytes */
               (dvoid*) &col_width,(ub4 *) 0, (ub4) OCI_ATTR_DATA_SIZE,
   /* increment counter and get next descriptor, if there is one */
} /* while */
The checkerr() function is used for error handling. The complete listing can be found in the first sample application in Appendix B, "OCI Demonstration Programs".
The calls to OCIAttrGet() and OCIParamGet() are local calls that do not require a network round trip, because all of the select-list information is cached on the client side after the statement is executed.
See Also:
Explicit Describe of Queries
You can describe a query explicitly prior to execution. To do this, specify OCI_DESCRIBE_ONLY as the mode of OCIStmtExecute(); this does not execute the statement, but returns the select-list description.
To maximize performance, it is recommended that applications execute the statement in default mode and use the implicit describe that accompanies the execution.
The following code demonstrates the use of explicit describe in a select-list to return information about columns.
int i = 0;
ub4 numcols = 0;
ub2 type = 0;
OCIParam *colhd = (OCIParam *) 0;   /* column handle */
/* initialize svchp, stmhp, errhp, rowoff, iters, snap_in, snap_out */
/* set the execution mode to OCI_DESCRIBE_ONLY. Note that setting the mode to
OCI_DEFAULT does an implicit describe of the statement in addition to executing
the statement */
        (OCISnapshot *) 0, (OCISnapshot *) 0, OCI_DESCRIBE_ONLY));
/* Get the number of columns in the query */
checkerr(errhp, OCIAttrGet((dvoid *)stmthp, OCI_HTYPE_STMT, (dvoid *)&numcols,
                      (ub4 *)0, OCI_ATTR_PARAM_COUNT, errhp));
/* go through the column list and retrieve the datatype of each column. We
start from pos = 1 */
for (i = 1; i <= numcols; i++)
  /* get parameter for column i */
  checkerr(errhp, OCIParamGet((dvoid *)stmthp, OCI_HTYPE_STMT, errhp, (dvoid **)&colhd, i));
  /* get data-type of column i */
  type = 0;
  checkerr(errhp, OCIAttrGet((dvoid *)colhd, OCI_DTYPE_PARAM,
          (dvoid *)&type, (ub4 *)0, OCI_ATTR_DATA_TYPE, errhp));
Query statements return data from the database to your application. When processing a query, you must define an output variable or an array of output variables for each item in the select-list that you want to retrieve data from. The define step creates an association that determines where returned results are stored, and in what format.
For example, to process the following statement you would normally need to define two output variables, one to receive the value returned from the name column, and one to receive the value returned from the ssn column:
SELECT name, ssn FROM employees
    WHERE empno = :empnum
Fetching Results
If an OCI application has processed a query, it is typically necessary to fetch the results with OCIStmtFetch() or with OCIStmtFetch2() after the statement has completed execution. Oracle encourages the use of OCIStmtFetch2(), which supports scrollable cursors.
Fetched data is retrieved into output variables that have been specified by define operations.
If output variables are defined for a SELECT statement before a call to OCIStmtExecute(), the number of rows specified by the iters parameter is fetched directly into the defined output buffers
See Also:
Fetching LOB Data
If LOB columns or attributes are part of a select-list, they can be returned as LOB locators or actual LOB values, depending on how you define them. If LOB locators are fetched, then the application can perform further operations on these locators through the OCILobXXX interfaces.
See Also:
Setting Prefetch Count
In order to minimize server round trips and optimize the performance, the OCI can prefetch result set rows when executing a query. You can customize this prefetching by setting either the OCI_ATTR_PREFETCH_ROWS or OCI_ATTR_PREFETCH_MEMORY attribute of the statement handle using the OCIAttrSet() function. These attributes are used as follows:
  • OCI_ATTR_PREFETCH_ROWS sets the number of rows to be prefetched. If it is not set, then the default value is 1. If the iters parameter of OCIStmtExecute() is 0 and prefetching is enabled, the rows are buffered during calls to OCIStmtFetch2(). The prefetch value can be altered after execution and between fetches.
  • OCI_ATTR_PREFETCH_MEMORY sets the memory allocated for rows to be prefetched. The application then fetches as many rows as will fit into that much memory.
When both of these attributes are set, the OCI prefetches rows up to the OCI_ATTR_PREFETCH_ROWS limit unless the OCI_ATTR_PREFETCH_MEMORY limit is reached, in which case the OCI returns as many rows as will fit in a buffer of size OCI_ATTR_PREFETCH_MEMORY.
By default, prefetching is turned on, and the OCI fetches an extra row all the time. To turn prefetching off, set both the OCI_ATTR_PREFETCH_ROWS and OCI_ATTR_PREFETCH_MEMORY attributes to zero.
Prefetching is not in effect if LONG columns are part of the query. Queries containing LOB columns can be prefetched, because the LOB locator, not the data, is returned by the query.
Scrollable Cursors in OCI
A cursor is a current position in a result set. Execution of a cursor puts the results of the query into a set of rows called the result set that can be fetched either sequentially or non-sequentially. In the latter case the cursor is known as a scrollable cursor.
A scrollable cursor provides support for forward and backward access into the result set from a given position, using either absolute or relative row number offsets into the result set.
Rows are numbered starting at one. For a scrollable cursor, you can fetch previously-fetched rows, the n-th row in the result set, or the n-th row from the current position. Client-side caching of either the partial or entire result set improves performance by limiting calls to the server.
Oracle does not support DML operations on scrollable cursors. A cursor cannot be made scrollable if the LONG datatype is part of the select list.
Moreover, fetches from a scrollable statement handle are based on the snapshot at execution time. OCI client prefetching works with OCI scrollable cursors. The size of the client prefetch cache can be controlled by the existing OCI attributes OCI_ATTR_PREFETCH_ROWS and OCI_ATTR_PREFETCH_MEMORY.
Do not use scrollable cursors unless you require the functionality, because they use more server resources and can have greater response times than non-scrollable cursors.
The OCIStmtExecute() call has an execution mode for scrollable cursors, OCI_STMT_SCROLLABLE_READONLY. The default for statement handles is non-scrollable, forward sequential access only, where the mode is OCI_FETCH_NEXT. You must set this execution mode each time the statement handle is executed.
The statement handle attribute OCI_ATTR_CURRENT_POSITION can be retrieved using OCIAttrGet() only. This attribute cannot be set by the application; it indicates the current position in the result set.
For non-scrollable cursors, OCI_ATTR_ROW_COUNT is the total number of rows fetched into user buffers with the OCIStmtFetch2() calls since this statement handle was executed. Since non-scrollable cursors are forward sequential only, OCI_ATTR_ROW_COUNT also represents the highest row number seen by the application.
For scrollable cursors, OCI_ATTR_ROW_COUNT will represent the maximum (absolute) row number fetched into the user buffers. Since the application can arbitrarily position the fetches, this does not have to be the total number of rows fetched into the your buffers since the (scrollable) statement was executed.
The attribute OCI_ATTR_ROWS_FETCHED on the statement handle, represents the number of rows that were successfully fetched into the user's buffers in the last fetch call or execute. It works for both scrollable and non-scrollable cursors.
Use the OCIStmtFetch2() call, instead of the OCIStmtFetch() call, which is retained for backward compatibility. You are encouraged to use OCIStmtFetch2(), for all new applications, even those not using scrollable cursors. This call also works for non-scrollable cursors, but can raise an error if any other orientation besides OCI_DEFAULT or OCI_FETCH_NEXT is passed.
Scrollable cursors are supported for remote mapped queries. Transparent application Failover (TAF) is supported for scrollable cursors.
If you call OCIStmtFetch2() with the nrows parameter set to 0, the cursor is cancelled.
Increasing Scrollable Cursor Performance
Response time is improved if you use OCI client-side prefetch buffers. After calling OCIStmtExecute() for a scrollable cursor, call OCIStmtFetch2() using OCI_FETCH_LAST to obtain the size of the result set. Then set OCI_ATTR_PREFETCH_ROWS to about 20% of that size, and set OCI_PREFETCH_MEMORY if the result set uses a large amount of memory.
Example of Access on a Scrollable Cursor
Assume that a result set is returned by the SQL query:
SELECT empno, ename FROM emp
and that the table EMP has 14 rows. One use of scrollable cursors is:
/* execute the scrollable cursor in the scrollable mode */
OCIStmtExecute(svchp, stmthp, errhp, (ub4)0, (ub4)0, (CONST OCISnapshot *)NULL,
               (OCISnapshot *) NULL, OCI_STMT_SCROLLABLE_READONLY );
/* Fetches rows with absolute row numbers 6, 7, 8. After this call,
checkprint(errhp, OCIStmtFetch2(stmthp, errhp, (ub4) 3,
                               OCI_FETCH_ABSOLUTE, (sb4) 6, OCI_DEFAULT);
                               OCI_FETCH_RELATIVE, (sb4) -2, OCI_DEFAULT);
/* Fetches rows with absolute row numbers 14. After this call,
checkprint(errhp, OCIStmtFetch2(stmthp, errhp, (ub4) 1,
                               OCI_FETCH_LAST, (sb4) 0, OCI_DEFAULT);
/* Fetches rows with absolute row number 1. After this call,
                               OCI_FETCH_FIRST, (sb4) 0, OCI_DEFAULT);
/* Fetches rows with absolute row numbers 2, 3, 4. After this call,
                               OCI_FETCH_NEXT, (sb4) 0, OCI_DEFAULT);
/* Fetches rows with absolute row numbers 3,4,5,6,7. After this call,
the user's define memory is allocated. */
checkprint(errhp, OCIStmtFetch2(stmthp, errhp, (ub4) 5,
                               OCI_FETCH_PRIOR, (sb4) 0, OCI_DEFAULT);
checkprint (errhp, status)
 ub4 rows_fetched;
/* This checks for any OCI errors before printing the results of the fetch call
   in the define buffers */
 checkerr (errhp, status);
 checkerr(errhp, OCIAttrGet((CONST void *) stmthp, OCI_HTYPE_STMT,
         (void *) &rows_fetched, (uint *) 0, OCI_ATTR_ROWS_FETCHED, errhp));
