Applications Administration Guide > Getting Started >
Getting Started Prerequisites
Once the Siebel system is successfully installed, you need to enter license keys so that you and your organization can access the Siebel products that your organization has purchased. After the license keys have been entered, you are ready to set up your Siebel applications.
Before you can begin to use your Siebel applications, the software listed in Table 3 must be correctly installed.
Table 3. Required Software
For Information, See
Siebel Gateway Name Server
Siebel Installation Guide for the operating system you are using
Siebel Server
Siebel Database Server
Siebel Tools or Siebel Developer Web Client
Siebel Business Applications
Application-specific administration guide and this guide
Once these Siebel servers and applications are successfully installed, you can proceed to enter license keys for specific Siebel applications.
