Applications Administration Guide > Configuring the Inbox >
Setting Up Inbox Links to Views and SmartScripts
As an administrator you can specify that the Name field for the Inbox item drills down to a particular view and optionally runs a SmartScript. The Name field as a hyperlink is shown in Figure 10.
Multiple views can be associated with one Item type. Each view is assigned a sequence number. When users drill down on the Item hyperlink in the Inbox, they see the first view in the sequence that they have access to (based on their responsibilities).
How to Set up Views and SmartScripts for an Inbox Type
This task is a step in Process of Setting Up and Configuring Inbox.
NOTE:  If you have set a Name Drilldown action, then view records you set up are ignored.
To set up views and SmartScripts for an Inbox type
  1. Navigate to the Administration - Inbox screen > All Inbox Types view.
  2. In the Inbox Types list, select a record, and then click the Views view tab.
  3. In the Views list, create a new record and complete the necessary fields.
    Some fields are described in the following table.
    Specify the view that an end user sees when they drill down on an Inbox item. For ESS, use the EmpSS Form Player view.
    Sequence #
    Specifies the sequence in which views are available to the end user.
    Specifies the SmartScript to be run in the view.
    SmartScripts are primarily used for ESS integration with Inbox. For example, an ESS Summary Form SmartScript.
