Applications Administration Guide > Configuring the Inbox >
Setting Up Inbox Approval Translations
If your Siebel application is multilingual, you need to create a translation record for each language.
Use the Translations view to specify Inbox type names in other languages.
This task is a step in Process of Setting Up and Configuring Inbox.
To set up an Inbox translation
  1. Navigate to Administration - Inbox screen > All Inbox Types view.
  2. In the Inbox Types list, select the approval record and click the Translations view tab.
  3. In the Translations list, create a new record and complete the necessary fields.
    Some fields are described in the following table.
    Display Name
    Translation of the Inbox type Name.
