Applications Administration Guide > Initial Setup >
About Initial Setup
Once your Siebel products are successfully installed, you need to perform a number of tasks to set up and administer the application.
Initial setup tasks are those which must be completed in order for your Siebel applications to work correctly, and then may be done infrequently, for instance, as your company grows.
Ongoing tasks are done on an occasional or ongoing basis, and are described in Ongoing Application Administration Tasks.
