Applications Administration Guide > Ongoing Application Administration Tasks >
Setting System Preferences
System preferences control how Siebel applications operate in your environment. You need to review default settings and modify these as appropriate for your environment.
For a list of the system preferences in Siebel applications, see System Preferences.
To set system preferences
  1. Navigate to Administration - Application screen > System Preferences view.
  2. Check that the default System Preference Values are correct in your environment, or change values for system preferences as needed.
    Some system preferences may not take effect until the affected components are restarted. (For information about shutting down and starting Siebel Server components such as an Object Manager, see the Siebel System Administration Guide.)
