Applications Administration Guide > Global Target List Management >
Applying Target Lists (End User)
Once you or an administrator have created target lists, you can apply them. For a target list to be applied, you must be in a target list-enabled view.
This task is a step in Process of Global Target List Management.
To apply a target list
  1. Navigate to a screen where target lists are enabled.
  2. On the toolbar, click the Apply Target List button.
  3. In the Apply Target List dialog box:
    1. Select one or more lists
    2. Click Available to preserve the current query (That is, records are displayed only if they are in both the list and the current query.)
    3. Click OK, Union, or Intersection to apply the list(s)
