Siebel Assignment Manager Administration Guide > Assignment Rule Administration > Adding Employees, Positions, and Organizations to Assignment RulesThis topic provides procedures for adding employees, positions, and organizations to assignment rules. This task is a step in Process of Defining Assignment Rules. Assignment Manager can assign employees, positions, and organizations based on their association with their parent organization. For example, only employees or positions associated with a specific organization can be assigned to an assignment object even if other employees or positions associated with other organizations qualify. Positions assigned to an assignment object can also have their associated organizations assigned. This functionality is called multitiered assignment, and you must configure the appropriate assignment object before implementing. For information about configuring assignment objects for multitiered assignment, see Configuring Assignment Objects for Multitiered Assignment. Alternatively, you can set a default employee, position, or organization for assignment objects. For example, if you want records for a given assignment object assigned to a certain employee, you can change the Default Employee property on the assignment object using Siebel Tools. For more information about the Default Employee, Default Position, and Default Organization properties, see Object Types Reference. For more information about setting these properties, see Configuring Assignment Object Properties. NOTE: Assignment Manager does not prevent you from adding employees to an assignment rule that performs position assignments. If a particular rule is set for position assignment and the rule has employees associated with the assignment rule, Assignment Manager considers only the position candidates. To add employees to an assignment rule
NOTE: If the All People value is selected in the Person Candidates Source field for the assignment rule, all candidates are evaluated even if they are not listed in the Employee Candidates list or the Position Candidates list. Table 26 shows select predefined fields available. NOTE: For assignment purposes, an employee's organization is the organization corresponding to the employee's primary position. For example, if Employee A holds Position A where Position A is in the Sales East organization, then Employee A's organization is the Sales East organization. To add positions to an assignment rule
NOTE: If the All People value is selected in the Person Candidates Source field for the assignment rule, all candidates are evaluated even if they are not listed in the Employee Candidates list or the Position Candidates list. Table 27 shows select predefined fields available for editing. After you add positions for an assignment rule, only the active employees for each position are available. If Assignment Manager assigns the position, employees for the position have visibility to the assigned object. To delete system-assigned positions from individual assignment objects, or to manually assign other positions, see the procedure in Maintaining the Manually Assigned Primary Position. You can configure Assignment Manager to define additional fields for Positions associated with an assignment rule. For more information on defining fields for Positions, see Configuring Assignment Objects to Copy Additional Columns to the Team Table. To add organizations to an assignment rule
NOTE: If the All Organizations value is selected in the Organization Candidates Source field for the assignment rule, all candidates are evaluated even if they are not listed in the Organization Candidates list. Table 28 shows select predefined fields available for editing. |
Siebel Assignment Manager Administration Guide |
