Siebel Assignment Manager Administration Guide > Assignment Rule Administration > Deactivating Assignment Policies to Disable Dynamic AssignmentYou may find at some point that you no longer need certain assignment rules. When this occurs, you can deactivate those assignment rules. To disable dynamic assignment for an assignment object, deactivate the assignment policy for that object. NOTE: Assignment Manager uses the database time to determine whether a rule is active or not. To deactivate an assignment policy to disable dynamic assignment
Workflow components process only active assignment policies that have not expired; therefore, you can deactivate an assignment policy by expiring it. NOTE: After deactivating an assignment policy, you must generate triggers again for the changes to take effect. |
Siebel Assignment Manager Administration Guide |
