Siebel Automotive Guide > Setting Up Preventive Maintenance >
Associating a PM Plan with a Product
After you define the PM plan triggers, use this procedure to associate it with a product you added. See Managing Products for more information on using Products.
This task is a step in Process of Setting Up Preventive Maintenance.
To associate a PM plan with a product
  1. Navigate to the Preventive Maintenance screen > Preventive Maintenance List view.
  2. Select a PM plan record.
  3. Click the Products view tab.
  4. In the Products list, add, edit, or delete records.
Related Topics
