Siebel Automotive Guide > Setting Up Preventive Maintenance >
Associating a PM Plan with Vehicles
When you associate the PM plan with a product, use this procedure to associate it to a specific vehicle or vehicles. After a preventive maintenance (PM) plan is associated with a vehicle, you can run the PM engine to create preventive maintenance actions, activities, and service requests for the vehicle.
This task is a step in Process of Setting Up Preventive Maintenance.
To associate a PM plan with a vehicle or vehicles
  1. Navigate to the Preventive Maintenance screen > Preventive Maintenance List view.
  2. Select a PM plan record.
  3. Click the Products view tab.
  4. Select a product record.
  5. Scroll down to the Assets list, add, edit, or delete records.
    NOTE:  This procedure can also be done using the Preventive Maintenance view of the Vehicles screen.
Related Topics
