Configuring Siebel eBusiness Applications > Editing Applet Layout >
Export the Preview to an HTML File
After previewing an applet layout, you can export it to an HTML file for later viewing.
To export the preview displayed in the Applet Layout Editor
  1. While in Preview mode, select File > Export.
  2. In the dialog box that appears, choose a file name and define siebel_tools_installation\tools\public\enu as the directory.
    You need to specify this directory so that image files, such as buttons, are rendered correctly in the HTML file.
