Configuring Siebel eBusiness Applications > Editing Applet Layout > Positioning Controls in a Grid LayoutGrid layout allows you to position controls anywhere in the applet layout. NOTE: Do not resize or position controls by modifying object properties in the Object List Editor. Instead, always use the layout editor. |
Configuring Siebel eBusiness Applications |
