Configuring Siebel eBusiness Applications > Editing Applet Layout >
Making Controls the Same Size in a Grid Layout
Grid layout allows you to make Controls or List Columns the same size as other Controls and List Columns. To resize controls
- Navigate to the applet you want to edit, right-click, and then choose Edit Web Layout.
- In the Mode field of Web Controls toolbar, choose the applet mode that you want to edit.
- In the Layout Canvas, hold down the Shift key, and then click the controls you want to resize.
The last item selected is the one to which all other items will be resized.
Perform the following tasks as necessary:
Make selected controls the same width. |
Make selected controls the same height. |
Make selected controls the same size. |
- Choose File > Save.
