Configuring Siebel eBusiness Applications > Editing Applet Layout >
Configuring Controls and List Columns to Appear in More Mode Only
You can configure applets to show a limited set of fields by default and then show more fields when the user clicks the More button. The applet has two modes, a Less mode and a More mode. The user can toggle between these modes to display more or fewer controls or list columns.
The Mode property of the Applet Web Template Item object determines the mode in which the control or list column is displayed.
To configure controls or list columns to appear in More mode only
  1. In the Applet Layout Editor, highlight the control.
  2. Right-click and then choose More.
    A border appears around the control or list column and a down arrow icon appears next to it.
    The Mode property of the corresponding Web Template Item is set to More.
NOTE:  The More/Less feature is not supported for Pop-up applets. For more information about Pop-up applets, see Pop-Up Windows.
