Configuring Siebel eBusiness Applications > Editing Applet Layout > Deleting Controls and List ColumnsYou can cut or delete controls from an applet layout without having to delete the corresponding Control and List Column object types. CAUTION: When working in language override mode, do not delete controls or list columns from applet layouts. Instead, set the Visible property to FALSE. If you delete controls or list columns when working in language override mode, the corresponding items will be deleted for all languages, not just the one in which you are working. You can select multiple controls by holding down the Shift key and then selecting the controls you want to delete. |
Configuring Siebel eBusiness Applications |
