Configuring Siebel eBusiness Applications > Configuring Applets > About Applet Controls and List Columns > Label ControlsA label control, is a visual aid only. It is not tied to a business component field and has no data display or entry capabilities. Use a label control when you need to place wording somewhere inside the form applet. NOTE: If a caption has any HTML reserved characters, such as &, <, >, ., then it should be HTML encoded as &, <, >, ", respectively. |
Configuring Siebel eBusiness Applications |
