Configuring Siebel eBusiness Applications > Configuring Applets >
Adding Web Templates to Applets
You add Web templates to applets using the Object List Editor. You need to add templates to applet when you want to define additional modes for applets.
To add a Web template to an applet
  1. Navigate to the applet you want to modify.
  2. In the Object Explorer, select the Applet Web Template object type (child of Applet).
  3. In the Applet Web Templates list, right-click and choose new record.
  4. Use the information in the following table to complete the record:
    By convention this field is used to describe the mode of the Applet Web template.
    Applet Web template mode.
    Web Template
    Select Web template to associate to the applet.
Related Topic
About the Role of Applet Modes
