Configuring Siebel eBusiness Applications > Configuring Applets > About List AppletsA list applet allows you to display multiple records at one time. List applets present data in table format with multiple columns. Each row of the table represents a record from the applet's business component. List applets allow users to scroll through multiple records of data and see several fields for each record. An example list applet is shown in Figure 53. List applets are associated to a single business component. The List Column child object associates fields on the business component to applet Web template items, which are mapped to placeholders in the applet Web templates associated to the applet. The relationships between object types used to implement a list applet appear in Figure 54. NOTE: List applets use the List Column object type to expose fields in the applet. This is different from Form applets, which use the Control object type to expose fields. |
Configuring Siebel eBusiness Applications |
