Configuring Siebel eBusiness Applications > Configuring Business Components >
About System Fields
System fields are provided in all business components in standard Siebel eBusiness Applications. These fields represent the data from system columns.
Table 37 identifies the correspondences between system fields and system columns.
Table 37.  System Fields and Their System Columns
System Field Name
System Column Name
Description
Id (or blank)
ROW_ID
Primary key for the table.
Created
CREATED
Creation date and time of the row.
Created By
CREATED_BY
User logon ID of the person who created the row.
Updated
LAST_UPD
Date of last update of the row.
Updated (system field) is updated only when the row with the Updated column in it is changed.
Updated By
LAST_UPD_BY
User logon ID of the person who last updated the row.
System fields are automatically available to expose or manipulate in business components. You do not need to define them as business component fields. For example, system fields can be referenced in the Field property of controls, list columns, and other object definitions.
NOTE:  Do not change system fields, for example by renaming them. Changing Siebel system fields is not supported.
