Configuring Siebel eBusiness Applications > Configuring Business Components > Configuring Data-Driven Read-Only BehaviorBusiness components and fields can be configured as dynamically accessible, with their read-only status turned on and off depending on the value in a particular field in the current record. This is accomplished using one of the following Business Component object type user properties, depending on the requirement:
For more information about user properties, see Siebel Developer's Reference. When configuring read-only behavior, consider the following:
BC Read-Only FieldThis user property specifies a Boolean field that, when TRUE, causes all fields in the current record to become read-only. This also prevents the user from updating or deleting the record, but does not prevent the addition of new records to the business component. The Name and Value properties in the user property record are specified as follows:
An example of the use of BC Read Only Field is the situation in which you need to prevent users from updating inactive accounts. The Inactive Account field in an account record is a TRUE or FALSE field that, when TRUE, indicates that the account is inactive. To configure dynamic read-only behavior for the Account business component based on this field, add a business component user property child object definition to the Account business component, with the following property settings: Field Read Only FieldThis user property is similar to BC Read Only Field, in that it tests the field specified in the Value property and enforces a read-only restriction when the test field has a value of TRUE in the current record. However, unlike BC Read Only Field, the Field Read Only Field user property restricts one field in the same business component, rather than the entire business component record. The Name and Value properties in the user property record are specified as follows:
One Field Read Only Field user property must be created for each field you want to make conditionally read-only. An example of the use of Field Read Only Field is the situation in which you want to make the Competitor field in an account record read-only when the Type field has a value of Competitor. In other words, if an account record has been included because that account is a competitor, you do not want users to be specifying that account's competitors. The following procedure describes how to accomplish this. To restrict the Competitor field in an account based on the account's type
Parent Read Only FieldThis property, like BC Read Only Field, places a read-only restriction on an entire business component, rather than a single target field. This restriction occurs when a TRUE or FALSE test field has a TRUE value. However, unlike BC Read Only Field and Field Read Only Field, this user property is used to place a restriction on a child or grandchild (and so on) business component of the business component containing the test field. In the other user properties, the read-only restriction is placed on the business component containing the test field, or on another field in the same business component. Parent Read Only Field is used primarily to restrict the detail records in a multi-value group. It could also be used to restrict the detail records in a master-detail view, but in that case you need to make sure that the restricted business component is not also used in the context of some other business object than the intended one. The Name and Value properties in the user property record are specified as follows:
The business component to be conditionally restricted is the one to which you add the user property as a child object definition. The business component containing the test field must be a parent or grandparent of the restricted business component by way of a link or series of link relationships. An example of the use of this user property is the situation where you want to disable the update of the Account Address multi-value group when the account record has a Type of Competitor. To accomplish this, you add the same calculated field as in the Field Read Only Field example, and then add a user property to the Business Address business component with the following values: This causes the Account Address multi-value group to be read-only when the account record is for a competitor. NOTE: When using the Parent Read Only Field user property, the test field must have its Link Specification property set to TRUE. Otherwise the dynamic read-only functionality does not work. However, if the child record is displayed in the multi-value field in the parent business component, it is not necessary to have the Link Specification property of the field set to TRUE. |
Configuring Siebel eBusiness Applications |
