Configuring Siebel eBusiness Applications > Configuring Business Components > Creating Business ComponentsYou use the New Business Component Wizard to create Business Component objects. You may need to create new business components when existing business components are not a good functional or technical fit to your business requirements. For example, suppose you need to define scripting logic that is different from any similar, out-of-the-box business components or suppose you want to predefault record values to a different type in order to differentiate records from other records in the same table. In both cases, you would create a new business component. For more information on reusing existing objects and creating new objects, see About Object Reuse. To open the Business Component wizard
Configuring Siebel eBusiness Applications |
