Configuring Siebel eBusiness Applications > Specialized Behavior Supported by Web Templates > Displaying Server Side ErrorsWhen a server side error occurs on submitting a form, SWE shows the same page again with the error message displayed within the page. For errors that occur outside of a form submission SWE continues to use the application's Error Page. This error message display is mainly developed for showing error messages within a form. It is also used to show an error message in an error page to replace the to be depreciated pageitem.errorMsg way of showing error messages. To display the error message within a form, place the following tags inside <swe:this property="FormattedHtml"/> The error messages are shown in plain text, but each error message takes a new paragraph. It is the responsibility of the enclosing HTML tags to modify the font and style of the error message. Sometimes, the error message may not be visible; this is because the font uses the same color as the background. If the application developer does not use error tags in the swt files, the code automatically generates an error node (a CSSSWEErrorSWX instance). This automatically generated error node is inserted as the first child of the enclosing page/form node. The syntax of the
<swe:this property="FormattedHtml"/> This tag should be used within all You should also use this tag instead of the An example of the use of this tag is: <b><font color="red"> <swe:this property="FormattedHtml"/> </font></b> When the form is being rendered when there are no errors, the contents of the |
Configuring Siebel eBusiness Applications |
