Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard > Configuring Labels for Customer Dashboard GoTo ViewsYou can specify the view labels for each view that you configure to appear in the GoTo drop-down list. This task is a step in the Process for Configuring the Customer Dashboard. To configure labels for GoTo views
Configuring Siebel eBusiness Applications |
