Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard >
Activating the SmartScript Player
When using the Customer Dashboard with SmartScripts you need to verify that the Notify Dashboard property of the Smart Script Player Applet (Tree Only) is set to true.
This task is a step in the The Process of Configuring SmartScripts to Populate the Customer Dashboard.
To verify that the Notify Dashboard user property is set to TRUE
  1. Locate the applet named Smart Script Player Applet (Tree Only).
  2. Locate the applet user property named Notify Dashboard.
  3. Verify that the value of the user property is Y.
