Configuring Siebel eBusiness Applications > Configuring EIM Interfaces > About EIM Object Types >
Foreign Key Mapping Column Object Type
Each Foreign Key Mapping Column object definition identifies a piece of the user key columns; that is, one of the attribute columns used to locate rows in the table the foreign key points to. The user key columns, taken together, uniquely identify rows in that table. The Foreign Key Mapping Column object definitions identify these user key columns to the interface table, so that foreign key values can be derived when import or export takes place.
