Configuring Siebel eBusiness Applications > Configuring EIM Interfaces > About EIM Object Types >
Labeling Data Loaded in EIM As No Match Row Id Instead of NULL
When you are loading data through EIM and a primary child column has no match, it is labeled as NULL, whereas loading it through the user interface would produce No Match Row Id.
To fix the problem you need to open the record set in the client user interface and manually step through each record created by EIM—each instance of a NULL value for PR_TERR_ID will be replaced with No Match Row Id.
For more information, see Using the Check No Match Property with a Primary Join.
