Configuring Siebel eBusiness Applications > Configuring EIM Interfaces >
EIM Object Specifications
The topics in this section detail objects specifications that EIM uses.
EIM Interface Table
EIM Interface Table Columns
Generic EIM Interface Table Columns for EIM Processing
EIM Interface Table Columns for Processing a Mapping to a Specified Table
EIM Interface Table Columns for Foreign Key Processing
EIM Interface Table Columns for Foreign Keys
EIM Interface Table Column for Each Attribute on the Target Table
EIM Table Mapping Objects Based on the Target Table
Attribute Mapping objects for Each EIM Interface Column Generated
Foreign Key Mapping for Each Foreign Key Column on the Target Table
Foreign Key Mapping Columns for each Foreign Key Mapping object
For detailed information about EIM, see Siebel Enterprise Integration Manager Administration Guide.
EIM Interface Table
EIM interface table object specifications are summarized in Table 18.
Table 18.  EIM Interface Table Object Specifications
Specification
Value
Target Table
Selected by the developer
EIM Delete Proc Column
T_DELETED_ROW_ID
EIM Export Proc Column
T_EXPORTED_ROW_ID
EIM Merge Proc Column
T_MERGED_ROW_ID
EIM Interface Table Column specifications are covered in Table 19.
Table 19.  System Columns on the EIM Interface Table
Name
Physical Type
Length
Type
EIM Processing Column
CONFLICT_ID
Varchar
15
System
FALSE
CREATED
Date Time
7
System
FALSE
CREATED_BY
Varchar
15
System
FALSE
IF_ROW_BATCH_NUM
Number
22
System
FALSE
IF_ROW_MERGE_ID
Varchar
15
System
FALSE
IF_ROW_STAT
Varchar
30
System
FALSE
IF_ROW_STAT_NUM
Number
22
System
FALSE
LAST_UPD
Date Time
7
System
FALSE
LAST_UPD_BY
Varchar
15
System
FALSE
MODIFICATION_NUM
Number
22
System
FALSE
ROW_ID
Varchar
15
System
FALSE
For each EIM Table Interface, the columns shown in Table 20 are created to facilitate processing. You cannot change the values of these columns.
Table 20.  Generic EIM Interface Table Columns for EIM Processing
Name
Physical Type
Length
Type
User Name
T_DELETED_ROW_ID
Varchar
15
Data (Private)
Deleted ROW_ID from base table
TRUE
T_EXPORTED_ROW_ID
Varchar
15
Data (Private)
Exported ROW_ID from target table
TRUE
T_MERGED_ROW_ID
Varchar
15
Data (Private)
Merged into ROW_ID from target table
TRUE
There are five of these columns for each EIM Table Mapping object, with the properties listed in Table 21.
Table 21.  EIM Interface Table Columns for Processing a Particular Mapping
Column
Value
Name
Derived from the name of the target table:
"T_"+ [EIM Table Mapping Name without the "CX_"]+ "_"+ [Process-specific suffix]
Physical Type
Depends on the process to which the column is related
Length
Type
User Name
Name of the EIM Table Mapping object for which the column is being created
TRUE
For example, if the target table selected by the user is CX_SEC_LEV, an EIM Table Mapping object is created. The following four column objects are generated, with the corresponding default properties (Table 22):
Table 22.  EIM Interface Table Columns for Processing a Mapping to CX_SEC_LEV
Name
Physical Type
Length
Type
User Name
T_SEC_LEV_EXS
Character
1
IFMGR: Exists
CX_SEC_LEV
TRUE
T_SEC_LEV_RID
Varchar
15
IFMGR: ROW_ID
CX_SEC_LEV
TRUE
T_SEC_LEV_STA
Number
22
IFMGR: Status
CX_SEC_LEV
TRUE
T_SEC_LEV_UNQ
Character
1
IFMGR: Unique
CX_SEC_LEV
TRUE
A column is created for each foreign key on the relevant EIM Table Mapping object (that is, the target table). These columns have the properties listed in Table 23.
Table 23.  EIM Interface Table Columns for Foreign Key Processing
Column
Value
Name
Derived from the target table name and the corresponding foreign key column on the target table in the following format:
[Target Table name (with the "CX" prefix replaced by "T")]+[Target table foreign key column]
Type
Set to IFMGR: Fkey
Physical Type
Physical type of foreign key column on Target Table (typically Varchar)
Length
Length of foreign key column on Target Table (typically 15)
User Name
[Target Table (or EIM Table Mapping) name]+"."+[Foreign key column name]
For example, if CX_SEC_LEV contains foreign key columns called OPTY_ID and ACCNT_ID to the S_OPTY and S_ORG_EXT tables, respectively, the following EIM Table Columns are generated as shown in Table 24.
Table 24.  EIM Interface Table Columns for Processing Foreign Keys in CX_SEC_LEV
Name
Physical Type
Length
Type
User Name
T_SEC_LEV_OPTY_ID
Varchar
15
IFMGR: Fkey
CX_SEC_LEV.OPTY_ID
T_SEC_LEV_ACCNT_ID
Varchar
15
IFMGR: Fkey
CX_SEC_LEV.ACCNT_ID
A separate foreign key column will be created for each U1 user key column on the foreign key tables. The columns have the following properties listed in Table 25.
Table 25.  EIM Interface Table Columns for Foreign Keys
Column
Value
Name
[First four letters of foreign key table name without the "S_" prefix, trimmed to remove any trailing "_"characters] + "_"+[foreign key column name on target table]
Physical Type
Physical type of the user key column on the target table (typically Varchar)
Length
Length of these columns will correspond to the length of user key columns upon which they are based (typically 15)
Type
Data (Public)
Continuing with the CX_SEC_LEV example the columns would have the properties listed in Table 26.
Table 26.  EIM Interface Table Columns for CX_SEC_LEV Foreign Keys
Name
Physical Type
Type
OPTY_BU_ID
Varchar
Data (Public)
OPTY_NAME
Varchar
Data (Public)
OPTY_PR_DEPT_OU_ID
Varchar
Data (Public)
ORG_BU_ID
Varchar
Data (Public)
ORG_NAME
Varchar
Data (Public)
ORG_LOC
Varchar
Data (Public)
NOTE:  Depending on the base column type, corresponding EIM columns are generated accordingly.
Attribute columns on the target table are those of type Data (Public) that have a null Foreign Key Table property. These EIM interface table columns will have the properties listed in Table 27.
Table 27.  EIM Interface Table Columns for Each Attribute on the Target Table
Column
Value
Name
[Prefix entered—for example, CON or ACCNT]+"_"+[name of the corresponding column in the target table]
Physical Type
Data (Public)
Length
Length of corresponding column in the target table
User Name
Name of corresponding column in the target table
For example, if you enter a prefix of SECL and have the following attribute columns in CX_SEC_LEV: NAME (Varchar 100), DESC_TEXT (Varchar 250), and AUTO_UPDATE (Char 1), the following EIM interface table columns are generated as shown in Table 28.
Table 28.  EIM Interface Table Columns for Each Attribute on CX_SEC_LEV
Name
Physical Type
Length
Type
User Name
SECL_NAME
Varchar
100
Data (Public)
Security Level Name
SECL_DESC_TEXT
Varchar
250
Data (Public)
Security Level Description
SECL_AUTO_UPDATE
Char
1
Data (Public)
Auto Update Flag
The name and destination columns will be set to the name of the target table. The processing column properties will correspond to those that have been automatically generated. For examples, see Table 29.
Table 29.  EIM Table Mapping Objects Based on the Target Table
Column
Value
Name
CX_SEC_LEV
Destination Table
CS_SEC_LEV
EIM Exists Proc Column
T_SEC_LEV_EXS
EIM Row Id Proc Column
T_SEC_LEV_RID
EIM Status Proc Column
T_SEC_LEV_STA
EIM Unique Proc Column
T_SEC_LEV_UNQ
Attribute Mapping objects should have the property values listed in Table 30 for each EIM interface column generated:
Table 30.  Attribute Mapping Objects for Each EIM Interface Column
Object
Value
Name
Attribute column on target table
Interface Table Data Column
Name of corresponding EIM interface table column generated (Table 28)
Base Table Attribute Column
Name of attribute column on target table
A separate Foreign Key Mapping object is created for each foreign key mapping column on the target table. The properties listed in Table 31 are set for each.
Table 31.  Foreign Key Mapping for Each Foreign Key Column on a Target Table
Object
Value
Name
Name of the user key column
Foreign Key Column
User Key
Name of the U1 user key of the foreign key table
EIM Foreign Key Proc Column
Corresponding EIM interface table column for foreign key processing:
"T_"+[Target table name without "CX_" prefix] +"_"+[user key column name]
Continuing with the CX_SEC_LEV example, Table 32 shows the foreign key mapping.
Table 32.  Foreign Key Mapping for Each Foreign Key Column on CX_SEC_LEV
Name
Foreign Key Column
User Key
OPTY_ID
OPTY_ID
S_OPTY_U1
T_SEC_LEV_OPTY_ID
ACCNT_ID
ACCNT_ID
S_ORG_EXT_U1
T_SEC_LEV_ACCNT_ID
A separate Foreign Key Mapping Column object is created for each user key column in the user key specified for the parent Foreign Key Mapping object (Table 31). The following properties are set for each foreign key mapping column (Table 33):
Table 33.  Foreign Key Mapping Columns for Each Foreign Key Mapping Object
Column
Value
Name
Name of the Foreign Key Mapping Column.
Interface Data Column
EIM interface table column to which the user key column on the target table should be mapped.
This EIM interface table column is generated according to the specifications in Table 25.
User Key Attribute
Name of the corresponding user key column that belongs to the user key specified in Table 31.
Continuing with the CX_SEC_LEV example, Table 34 shows the foreign key mapping.
Table 34.  Foreign Key Mapping Columns for CX_SEC_LEV
Name
User Key Attribute
OPTY_BU_ID
OPTY_BU_ID
BU_ID
OPTY_NAME
OPTY_NAME
NAME
OPTY_PR_DEPT_OU_ID
OPTY_PR_DEPT_OU_ID
PR_DEPT_OU_ID
ORG_BU_ID
ORG_BU_ID
BU_ID
ORG_NAME
ORG_NAME
NAME
ORG_LOC
ORG_LOC
LOC
