Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Navigating to Entity Relationship Diagrams
You navigate to ERDs using the Object Explorer and Object List Editor in Siebel Tools.
To navigate to an entity relationship diagram
  1. In the Object Explorer, select the Entity Relationship Diagram object type.
  2. Select a record in the Entity Relationship Diagram list.
  3. Right-click and then choose Edit Entity Relationship Diagram.
    The Entity Relationship Diagram Canvas appears.
