Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Defining Entity Attributes
After you have created an ERD that includes entities, you can define attributes for each entity.
This task is a step in Process of Creating and Binding Entity Relationship Diagrams.
To define entity attributes
  1. Navigate to an entity relationship diagram.
    For instructions, see Navigating to Entity Relationship Diagrams.
  2. In the ERD canvas, select an entity.
  3. In the Entity Attributes list, right-click and then choose New Record.
  4. Enter a Name and a Data Type for the entity attribute.
