Configuring Siebel eBusiness Applications > Displaying Images >
Configuring Buttons to Display Images
You can associate bitmap objects with button controls to display images instead of text, much like a Toolbar icon. Unlike a Toolbar icon, however, a bitmap button control is a command button in the applet. A good example of the use of a Bitmap object with a button control in an applet is the More/Less button. The More/Less button appears in the upper-right corner of many applets. The control uses a bitmap object called BTTNS_MORE that belongs to the Bitmap Category HTML Control Icons.
To configure buttons to display images
  1. Define a bitmap object.
    See Creating Bitmap Categories and Bitmap Objects.
  2. Define the following properties of the button control:
    • HTML Bitmap. Defines the Bitmap object used when the button is active.
    • HTML Disable Bitmap. Defines the Bitmap object to use when the button is inactive.
      For more information about controls, see About Applet Controls and List Columns.
