Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values >
MLOV Upgrade Utility Parameters
To run the MLOV Upgrade Utility, complete the dialog boxes listed in Table 56 and enter or select the values as you go.
Table 56.  MLOV Upgrade Utility
In This Dialog Box
Enter Or Select The Following
Siebel Enterprise Parameters: Gateway Name Server Address
Enterprise Server Address
Installation and Configuration Parameters: Siebel Server Directory
Installation and Configuration Parameters: Siebel Database Server Directory
Database Server Options: Siebel Database Operation
Run Database Utilities
Database Utilities: Database Utility Selection
Multilingual List of Values Conversion
MLOV Parameters: MLOV Operation
Validate or Translate, depending on the mode you want to run.
Installation and Configuration Parameters: Language Selection
Base language of your Siebel application.
Installation and Configuration Parameters: RDBMS Platform
RDBMS Platform
Installation and Configuration Parameters: OBDC Data Source Name
Installation and Configuration Parameters: Database User Name
Database User Name
Database Password
Installation and Configuration Parameters: Table Owner
Table Owner Name
Table Owner Password
MLOV Parameters: Repository Name
Repository Name
Configuration Parameter Review
Review the parameters you have defined and then click Finish.
