Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values > Configuring Siebel Anywhere for Use with MLOV-Enabled FieldsSiebel Anywhere requires additional configuration to be able to use fields enabled for MLOVs. To configure Siebel Anywhere for MLOVs
After completing this procedure, you can perform standard tasks associated with Siebel Anywhere, such as creating a client repository upgrade kit and distributing to clients. NOTE: Distributing Siebel executable to multilingual remote clients requires additional configuration. See Siebel Anywhere Administration Guide. |
Configuring Siebel eBusiness Applications |
