Configuring Siebel eBusiness Applications > Configuring Links >
About the Search Specification Property
The Search Specification property of a link is applied to the child business component. Be aware that a Search Specification can also be applied at the applet level, and any Search Specifications that exist at the applet level will be added to this Search Specification by using the query operator AND.
NOTE:  Sort Specification applies only to association lists.
