Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets >
About MVG Applets
MVG applets appear when the user clicks the select icon in the originating applet. It lists the multi-value group business component records that are detail records in the master-detail relationship with the current originating business component record. It also provides the means to add and delete detail records. The multi-value group applet contains list column object definitions that present the data from corresponding fields in the multi-value group business component.
The multi-value-group applet has the following important properties:
  • Business Component. Identifies the multi-value group business component.
  • Class. Enter a value of CSSFrameList in this property. This setting indicates that this is a standard list applet.
  • Type. Enter a value of MVG in this property. This setting indicates that this is a multi-value group applet. This configures the behavior of the dialog box and button controls.
  • Title. Identifies the multi-value group applet to appear in the title bar.
The List Column object definitions in the multi-value group applet have the following important property:
  • Field. Identifies the field in the multi-value group business component from which the list column displays data.
    For more information on field data types, see About Field Data Types.
