Configuring Siebel eBusiness Applications > Online Help Development > Customer Applications >
Customizing Help Content
Since the help consists of HTML pages, you can use any HTML editor to change the content of a help topic.
To customize help content
  1. Find the HTML file you want to change.
    For a list of source files, see Help Source Files.
  2. Open the HTML file, make your changes, and save the file.
    NOTE:  If a redirect tag exists in the file, be sure to remove the tag. The following is an example of a redirect tag:
    <META HTTP-EQUIV="REFRESH" CONTENT="1; URL=siebcomgeneric.htm">
  3. Test your changes and update the HTML file on the Siebel Server.
    For more information, see Testing and Distributing Changes.
