Configuring Siebel eBusiness Applications > Online Help Development > Employee ApplicationsThe topics in this section describe the details of the help implementation in Siebel 7 employee applications. It explains the location of the help files and provides information about using Siebel Tools to change help calls. In addition, different options for customizing the online help to suit your requirements are discussed. If you customized the online help in earlier versions of your Siebel application, you can also find instructions for migrating your customized online help. The following topics are included:
NOTE: The help implementation is identical for employee and partner applications. Therefore, the information contained in the topics above applies to both employee and partner applications. |
Configuring Siebel eBusiness Applications |
