Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About the Siebel Operating Architecture > About Standard and High InteractivitySiebel applications are deployed in either standard interactivity or high interactivity mode. Standard interactivity mode resembles most traditional Web applications. It supports many different types of browsers. Page refreshes occur often, such as when users create new records, submit forms, and browse through lists of records. Customer applications are deployed in standard interactivity mode. High interactivity mode is designed to resemble a Windows client. It supports fewer browsers than standard interactivity mode, but it includes a set of features that make data entry easier for users. For example, page refreshes do not occur as often as they do in standard interactivity mode. Users can create new records in a list, save the data, and continue browsing without a page refresh having to occur. Siebel employee applications are typically deployed in high interactivity mode. Other features supported by high interactivity mode are:
NOTE: Partner applications can be deployed in either standard interactivity or high interactivity mode. One way to differentiate between standard and high interactivity modes is by the underlying technologies used by each mode (see Table 7).
Configuring Siebel eBusiness Applications |
