Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About Configuring Siebel Applications > Usage and Configuration of Non-Licensed ObjectsThe licensing agreement between Siebel Systems, Inc. and its customers is such that customers are only entitled to use and configure Siebel objects (for example, business components and tables) that belong to modules they have purchased. If a Siebel object is not exposed to the licensed user interface—through views that are exposed under the customer's license key—the customer is not entitled to use that object in custom configurations. Customers are, however, entitled to create new tables using Siebel Database Extensibility features and to create new business components and UI objects to expose these tables. |
Configuring Siebel eBusiness Applications |
