Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About Configuring Siebel Applications >
About Modifying Objects
When possible, modify existing objects rather than create new ones.
- Many existing objects have been configured for best performance; new or copied objects may not automatically inherit this same ability.
- Because you have an archived copy of the original object to revert back to (in the sample database), troubleshooting will be much easier. You can also use the comparison feature in Siebel Tools to determine what changes were made to the object that might be causing the problem.
- Repository and application maintenance requires less time and fewer resources.
- The SRF is smaller and compiles faster.
- Eliminating unnecessary copies of objects reduces the amount of redundancy in the repository.
- Because standard objects have already been thoroughly tested, less effort is required to test the application or resolve application errors.
- By reducing the number of repository objects being evaluated or upgraded, there is less effort required when upgrading your application.
