Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > Other Ways to Customize Application Behavior > Managing Web Content with Siebel eBriefingsSiebel Interactive technology allows customers to incorporate HTML documents stored either on the same or on a different Web site. By configuring business components based on the CSSBCExternalUrl and CSSBCVExternalUrl classes, and setting the appropriate field, field user property, and configuration file parameters, configurators can implement functionality for retrieving and displaying internal or external HTML content. Through this type of configuration, you can programmatically forward and execute search specifications against desired Web servers. This functionality is also ideal for managing large stores of internal HTML-based content which may have informational value for users (for example, FAQs and so on). For more information about eBriefings, see Siebel eBriefings Guide. |
Configuring Siebel eBusiness Applications |
